Import-JDM.com - Lista de Stock & Fotos
http://www.import-jdm.com" onclick="window.open(this.href);return false; - info@import-jdm.com
Secret-Services
Mensagem por Secret-Services »
Todos os artigos listados encontram-se em stock, tentamos manter esta lista actualizada diariamente.
Todos os users deste forum vão ter como de oferta os custos de envio para todas as suas encomendas no valor igual ou superior a 100€, para terem direito a esta oferta devem de indiciar o nick registado no forum na encomenda.
Para encomendas usar os contactos:
Loja Online -> http://www.import-jdm.com" onclick="window.open(this.href);return false;
Mail -> info@import-jdm.com
Tlm -> 933404285 – Patricio Garrido
Todas as semanas é acrescentado material a lista, estejam atentos!!!
Em breve vamos receber mais de: Toda Racing, Skunk2 Racing, Buddy Club, Spoon Sports, J's Racing, OEM Honda, Eagle e entre outras...
3x Password:JDM Shop Flag Banner - 20.00€
1x Password:JDM Shop Flag Banner (Re-Integration) - 20.00€
5x Spoon Sports Reservoir Tank Covers - 12.00€
1x Spoon Sports Air Cleaner EG - 78.00€
1x Spoon Sports Air Cleaner DC - 134.00€
1x Spoon Sports High Tension Code B16A/B18C - 267.00€
2x Spoon Sports Magnetic Bolt Set (Eng+Trans) - 38.00€
1x Spoon Sports Carbon Plug Cover B16A/B18C - 134.00€
1x Spoon Sports HeadGasket 2P B16A/B18C - 134.00€
1x Spoon Sports Aeroquip Clutch Slave Hose EG6 - 101.00€
1x Spoon Sports Radiator Stay Silver - 23.00€
1x Spoon Sports Radiator Stay Black - 23.00€
1x Spoon Sports Oil Filler Cap - 73.00€
1x Spoon Sports Radiator Cap Type D - 31.00€
1x Spoon Sports Radiator Cap Type F - 31.00€
2x Spoon Sports Thermo Switch All Models - 51.00€
2x Spoon Sports Thermo Stat EG/EK/DC2 - 76.00€
1x Spoon Sports Shift Knob Duracon - 51.00€
1x Spoon Sports Shift Knob Aluminum - 51.00€
1x Spoon Sports Strut Tower Bar Front AP1/2 - 178.00€
1x Spoon Sports Cross Beam Bar Rear AP1/2 - 134.00€
1x Spoon Sports Cross Beam Bar Front AP1/2 - 201.00€
1x Spoon Sports Sub Silencer - 78.00€
1x Toda Racing Catalogue & License Plate Frame - 15.00€
1x Toda Racing Tshirt Blue Type 1 L - 36.00€
1x Toda Racing Tshirt Blue Type 2 M - 36.00€
2x Toda Racing Tshirt White Type 1 L - 36.00€
2x OEM Honda Oil Cap ITR - 38.00€
1x OEM Honda Pistons ITR P73 81.00 STD - 185.00€
12x OEM Honda Oil Filter - 14.00€
1x Blox Racing Camshafts Type B K Series - 601.00€
1x Blox Racing 52mm Boost Gauge - 48.00€
2x Blox Racing 52mm Oil Pressure Gauge - 48.00€
1x Blox Racing 52mm Water Temperature Gauge - 50.00€
2x Blox Racing 52mm Oil Temp Gauge - 50.00€
1x Blox Racing Lowering Springs Civic/Del Sol EG - 164.00€
1x Blox Racing Donut Gasket 2.5" - 18.00€
1x Blox Racing Short Shifter Dual Bend 88-00 Civic / 90-01 Integra - 101.00€
1x Blox Racing Extented Nuts Open Blue Set 16x - 85.00€
1x Blox Racing Extented Nuts Open Purple Set 16x - 85.00€
1x Hondata 4 Bar Map Sensor K Series - 131.00€
1x Hondata K-Pro (Envio da Ecu PRA para instalação) - 850.00€
1x 5Zigen Header B18C 4-2-1 - 450.00€
3x Wilwood Kit EP3 Plain Rotors 0.81” Thk x 12.19” #160-5843 - 235.00€
1x Wilwood Kit SRP Rotors Drilled & Slotted Black Electro Coat Diameter: 12.19 Width: 0.81 #160-7103BK/160-7104BK - 200.00€
1x Wilwood Kit Hat #6288 - 100.00€
1x Wilwood Bracket Caliper Mounting #250-6289 262mm - 60.00€
1x Energy Suspension Motor Mount Inserts Black D Series #16.1105G - 53.00€
1x Evil Shift Light - 53.00€
1x Exedy Sports R Type Metal Kit Honda Civic/Crx 88-91 B16A1 (Cable) #HK03837 - 340.00€
1x Eagle Rods B16A - 320.00€
1x Golden Eagle Block Guard B16/B18 - 115.00€
1x Rear Lower Arm Bar Civic 96-00 EK - 61.00€
1x Cometic HeadGasket B16A/B18C Bore 81.50 Tickness 0.120" #C4232-120 - 175.00€
1x Clutch Masters FX400 6 Paddle EVO 7-9 #05-106-HDCB6 - 690.00€
1x ACT Clutch Kit Civic 90-91 Cable Tranny 6 Pads Metal D Series - 340.00€
1x Auto Meter Tach Pod Civic EG 92-95 - 80.00€
1x Megan Racing Guage Pod Single Civic 92-95 - 56.00€
1x Megan Racing Horizontal Single Universall - 56.00€
1x FF2 Lower Pieces para EG/EK 92-00 - 50.00€
1x Amber Corners Civic 92-95 EG 2-3D Hatchback - 47.00€
1x Amber Corners Civic 92-95 EG 4D Sedan - 47.00€
1x Amber Corners Crx 90-91 - 40.00€
1x Headlights Black Housing JDM Civic 92-95 EG - 127.00€
1x Taillights Red/White JDM Civic 92-95 2/4 Door - 120.00€
1x Supertech Valve Springs B18A/B18B/B20 DOHC Non-VTEC / D16A1 ZC #SPR-TS1015 - 180.00€
1x Cabos de Conversão de Distribuitor OBD0 para OBDI - 80.00€
1x Cabos de Conversão de OBD0 para OBDI - 110.00€
1x Cabos de Conversão de OBDI para OBDIIA - 100.00€
1x Cabos de Conversão de OBDIIA para OBDI - 90.00€
1x Cabos de Conversão de OBDIIB para OBDI - 90.00€
Aqui ficam umas fotos de algum material que tem passado pela Import-JDM.com
Cumprimentos
Pat
Última edição por Secret-Services em 20 dez 2011, 00:52, editado 30 vezes no total.
Secret-Services
Re: Import-JDM.com - Lista de Stock
Pessoal,
Ainda está semana mais material vai chegar!
Cumprimentos
Pat
_HIM_
Re: Import-JDM.com - Lista de Stock & Fotos
Mensagem por _HIM_ »
farois traseiros para del sol com a parte de cima em vermelho e a parte de baixo em cromado arranjas ?
cumps :D
http://pt.beruby.com/promocode/u02S7y" onclick="window.open(this.href);return false;
Secret-Services
_HIM_
Sim, arranjamos!
Envia um email para info@import-jdm com o pedido de preços e de preferencia com a foto dos farolins que procuras!
Obrigado!
Cumprimentos
Pat
Secret-Services
Boas,
Email enviado!
Cumprimentos
Pat
Secret-Services
PM's Respondidas!
Cumprimentos
Pat
luissilva
Veiculo: Honda Crx 1.6 16v
Mensagem por luissilva »
farois da frente para mk2 de halogeneo
ta quase!!!!!.
Secret-Services
luissilva,
Sim, arranjamos!
Obrigado!
Cumprimentos
Pat
hondadelsol
Veiculo: Honda delsol vti
Mensagem por hondadelsol »
qual é o preço da panela spoon N1???
e ja agr uma centralina da hondadata??
cunps
Secret-Services
hondadelsol,
Tens PM!
Cumprimentos
Pat
luissilva
sao estes os farois
ta quase!!!!!.
luissilva
para crx 1.6 16v 1989 ed9
ta quase!!!!!.
Del Sol
Mensagem por Del Sol »
tem algum kit estetico como aquele da ms designs? barras anti aproximação para o esi?
Secret-Services
del sol,
Sim, arranjamos kits esteticos e barras!
Envia um email para info@import-jdm com o pedido de preços e de preferencia com a foto ou link.
Obrigado!
Cumprimentos
Pat
Bloqueado
